Weird issue
Old Nov 15, 2025 | 09:16 PM
slammiam's Avatar
slammiam
Default Weird issue 2020 street glide cvo
Excessive crank case pressure?
File Type: mov
Old Nov 16, 2025 | 11:08 AM
hattitude's Avatar
hattitude
Did you have any major work done?
Were the trans and engine ever separated?
Was the bike in an accident?
Do you have oil leaks/drips at the bottom of engine/trans joint where the cases mate up?
I don't know about excessive crank case pressure, but it looks more to me like the gasket between the transmission and the engine cases is leaking...
Hard to tell in the video though.
It's a cheap gasket, but a bunch of labor to change.
Old Nov 16, 2025 | 03:41 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Help us out here, give some details...
Any work done on the bike?
Is it leaking?
Old Nov 16, 2025 | 04:53 PM
Max Headflow's Avatar
Max Headflow
Is it leaking?
Put your reading glasses on and look here..
Old Nov 16, 2025 | 05:35 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Max that gave me a headache...
I would check the torque on the transmission to engine bolts.
I couldn`t see in the video if any work had been performed on the bike in that area...
Old Nov 16, 2025 | 06:03 PM
slammiam's Avatar
slammiam
Found the issue.
It's a built 128. Friend had overfilled the oil which increased crankcase pressure and was forcing it out. Checked all torque values. Drained a quart and the fluid stopped bubbling out.
Thanks for all the info and even the parts
Probably need to tear it down and replace that gasket. Will do if it comes back.
Old Nov 16, 2025 | 07:23 PM
Max Headflow
Found the issue.
While lowering the oil level may have fixed the problem, it still shouldn't leak there at any time.. Well, maybe if the motor was so overfilled so much that it was blowing out everywhere..
You might want to keep your friend away from working on the bike..
Old Nov 16, 2025 | 09:42 PM
hattitude's Avatar
hattitude
Found the issue.
I'm no expert.... however...
If you checked torque values, then we can assume the gasket didn't leak because the joint was loose.
If increased crankcase pressure from an overfilled engine caused oil "bubbling out" from the gasket, it would appear the gasket is now compromised.
I've yet to see a compromised gasket heal itself. They tend to just get worse over time.
Although lowering of the oil level has stopped oil from "bubbling out", I suspect you still have a leak there.
You'll most likely need to fix it before long...
Old Nov 20, 2025 | 07:38 PM
Highwaymans's Avatar
Highwaymans
Doubtful you're "done" with that cure.....
Scudda
Nov 22, 2022 06:14 AM
nolabel
Jul 28, 2015 10:37 AM
HarDlife
EVO
Oct 2, 2013 10:40 PM
