HD amp?
Old Jun 25, 2014 | 06:54 PM
fmgsr's Avatar
fmgsr
Default HD amp?
I was thinking about having the dealer install the HD amp. Do I also need to change the speakers, or can I keep them ? Also, I see a lot of you guys going
With other brand amps?
Old Jun 25, 2014 | 07:21 PM
xhere's Avatar
xhere
Do the speakers also or you will toast the stock ones quickly.
People are installing aftermarket amps and speakers, pick your poison, the boom amp and speakers are just another option.
Old Jun 25, 2014 | 09:22 PM
MontyCop05's Avatar
MontyCop05
Originally Posted by fmgsr
I was thinking about having the dealer install the HD amp. Do I also need to change the speakers, or can I keep them ? Also, I see a lot of you guys going With other brand amps?
Before you waste money on the HD boom crap, take a trip over to the audio forum and look at the audio upgrade sticky for the 2014's. At least so you research your options prior to purchase. If you do decide to go the HD BOOM route don't pay the dealer to install it. It's a very simple install.
Old Jun 25, 2014 | 09:27 PM
Dave Thorpe's Avatar
Dave Thorpe
I have the HD Boom! upgrade amp and it sounds good to me. Dealer install is not that expensive, and the work is warrantied.
Old Jun 25, 2014 | 09:45 PM
dpmerrill's Avatar
dpmerrill
I rode with the Boom amp and stock speakers for a while and it sounded good. Later I just replaced the rear speakers with the 6.5's and that made it sound great. They really filled in the lower frequencies. I think the difference in sound with the rear speakers was well worth the extra $200.
Old Jun 25, 2014 | 10:15 PM
tbob's Avatar
tbob
I have the boom amp and speakers . Dealer gave me 20 percent off . I'm happy.
Old Jun 25, 2014 | 10:19 PM
dgreen1069's Avatar
dgreen1069
There seems to be a lot of haters towards the Harley upgraded speakers and amp. I have the system in my CVO and really like it. It sounds way better than the system I had on my Goldwing, and that was also a 300 watt amp but with smaller Polk speakers. The upgrade is pricey at about $1,000, but it is significantly louder and clearer than the stock system. It's also designed to fit perfectly which is a bonus!
Old Jun 25, 2014 | 10:25 PM
pretz's Avatar
pretz
I went with Biketronics components and they have life time warranty on speakers and amps. They sound awesome.
Old Jun 26, 2014 | 06:30 AM
MontyCop05's Avatar
MontyCop05
Exactly. Plus the $$$ install cost of $95/hr. For around 300-400 you can have a system that will beat the pants off of the HD Boom upgrade.
I wouldn't call myself a "Hater" either. I'm an educated consumer. I just can't bring myself to spend WAY more money on cheaply made, overpriced, and underperforming components, just because they say Harley on them and are "plug and play."
Old Jun 26, 2014 | 09:21 AM
dgreen1069's Avatar
dgreen1069
While I'm new to Harley audio, I find it very hard to believe any $300-$400 aftermarket option will sound better than the Boom amp/speaker upgrade. I'm sure there are $800-900 systems that will be very close or better, but they won't be plug and play.
I could not find actual specs on the Boom amp, but it is 75 watts per channel (RMS I believe) with little to no distortion at high volumes. I'm guessing it's a class D amp which allows for smaller packages and cooler operating temps. The best part is, it's plug and play and was designed to be mounted with the stock head unit. I normally wouldn't recommend a factory amp as an upgrade, but for a specialty vehicle with limited space, the HD Boom amp works well.
If anything, the speakers are where one could really improve the system. I'm happy with the Boom speakers in my CVO, but I have no doubt someone makes a better sounding speaker for less money. There are hundreds of 6.5" speaker options that would work!
