New Amp Dead Battery
#31
Glad to see you got you troubles fixed. On a side note, I am also attempting to PC my front light as you did. Did you un-pin the signal lights to get them apart or cut wires? What temp did you bake them at? I have been doing my items at 425 but I thought the signal bucket were plastic and didn't want to bake them that high.
#32
I removed the pins from the JAE connectors. The first one was tricky because I didn't use a safety pin or the right tool. I could reuse them both, but I found the replacement connectors cheap. I like to have backups because I'm always screwing around with something. The hardest part was the accessory light ground. It's riveted to the case. I ended up cutting that and soldering a new connection. That was I didn't have to remove the factory rivet. Now that I know how to pull the light assemblies apart it's not hard. Signal buckets are the same as the rest unless someone swapped them out.
I'm in the middle of building a big oven. Looking forward to getting that done. It's big enough to hold a bike frame.
SSG_B (04-10-2024)
#33
I would change out the battery for a start. Also where are you drawing power AND switched for the amp turn on? You may want to double check your pulling off of an actual switched circuit and not a constant hot.
also I’m assuming your running a Bluetooth module for the phone/music. What module are you using?
lastly when you ran your power for the amp did you add a Harley accessory harness or did you tap directly off of existing.
as long as your charging system is doing its job and charging/output at the correct amperage then that 50amp should more than handle the amp as long as the following applies;
1: your not running heated gear/other HIGH draw accessories all at the same time
2: your system is hooked up correctly and grounded well
3: your not playing music cranked sitting with the motor off
Well if I had read the whole thread I would have seen you resolved it, lol…..
‘Glad you figured it out.
‘hope this helps some.
#34
Mitch Wing
2014-2023 Touring Models
04-28-2022 04:10 AM
bgismo20
05-05-2008 09:29 AM
