2018+ Softail Models Breakout
Anyone Install the Handle Bar 12v aux. on Deluxe / Heritage ?
Old 05-25-2019, 07:55 AM
sumncguy's Avatar
sumncguy
sumncguy is offline
Default Anyone Install the Handle Bar 12v aux. on Deluxe / Heritage ?
I thought that the 12v aux port would be plug and play .. that is plug right into the accessories port adjacent to the SAE lead for the battery trickle charger.
I hit the Harley parts site to check on the part number and fitment .. found the following statement .. I thought, "What the hell does that mean ?" Maybe "or" should really be "of" ??
'18-later SoftailŽ models require seperate purchase or Electrical Connection Kit P/N 69201750
Thanks for the help folks !
Old 05-25-2019, 02:50 PM
dnd31's Avatar
dnd31
dnd31 is offline
Received 1,018 Likes on 220 Posts
Look at Namz power port harness. They have a couple depending on what your trying to do NHD-72674-11 and NOBD-PYH-CB
Old 05-25-2019, 07:51 PM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,514 Likes on 2,134 Posts
Yes, should read “of”.
It likely delivers more current then the accessory connector alone can provide. The kit uses the accessory connector as a switch and has a direct connector to the battery for the additional power required.
Old 05-26-2019, 06:04 AM
MHTR's Avatar
MHTR
MHTR is offline
Default Nhd-72674-11
"Look at Namz power port harness. They have a couple depending on what your trying to do NHD-72674-11 and NOBD-PYH-CB"
This is a picture of the NHD-72674-11. I assume it provides constant 12 volt, switched 12 volt, and ground?
JbaraJ
12-03-2015 02:56 AM
Nelmar
08-23-2014 04:50 PM
bobby84_00
Electrical/Lighting/Alarm
01-09-2011 03:23 AM
MarySue
06-27-2008 06:54 PM
ronyd
11-19-2007 08:31 PM
Quick Reply: Anyone Install the Handle Bar 12v aux. on Deluxe / Heritage ?
