2019 Fat Bob leaking oil
I recently helped my cousin install a new exhaust system on his 19 Fat Bob and when we started it up it began dumping oil. After looking around it appears as if when installing the front head pipe (whoever designed this was a madman) we nicked the oil radiator that sits between the pipes on the frame up front damaging a couple of the fins and such. At least I believe that is where the leak is coming from as I can see no other damage anywhere to any oil lines or anything. I saw that the lines are attached to the radiator with a weird sort of clip, is there anyway that we can replace the oil radiator ourselves without any special tools or is this something we have to take the bike in for? Also if anyone knows the part number for the oil radiator as I have looked all over the internet but to no avail. Thanks in advance.
Man that sucks. This link is your friend. You should be able to find the oil cooler and part numbers. Good luck.
Sorry forgot to paste the link. https://shop.outpostalaska.com/oempartfinder.htm
Well, it is his first post after all.....
OP, regarding swapping the oil cooler with regular tools yourself...I can’t recommend it after seeing the trouble you guys had with the pipe install. No shame in making mistakes, but don’t compound them with more complex problems. As Clint says...a man’s got to know his limitations. I’d get a well trusted indie, or the dealer to help dig you out. Best of luck.
touchdown204 (06-21-2019)
