Anyone using Custom Dynamics Triple Play?
Looking forward to hearing the results as well. I dont want to buy anything if its gonna trigger a code. Also anyone try the flash from the factory ? I just left a message with my Harley if this can be done to run the rear signals as running lights ..... crossing my fingers !!
I have a CD Triple Play on my 2019 Deluxe. When I installed my FP3 a couple of days ago it flagged up a bunch of codes to do with the rear lights which I cleared. Turn signals open circuit etc. It didn’t bring up the check light in the gauge though. Later on I’ll check to see if those codes have come back or stayed cleared.
Just wondering what unexpected issues I may run into.
I installed rear CD probeam turn signals, the H-D LED taillight and the CD magic strobe on my 2019 FLCHS. I haven’t ridden it a lot since then, but everything seems to operate fine run-turn-strobe. Just another data point.
Just to clarify. It didn’t throw the check engine light it all works absolutely fine.
Well, you did post to this thread on the 17th, so you have been reading about my issue, and that no one else seems to have any problems, so I’m sure you figured that it was an isolated issue to my particular module. Right?
