Stock 114 FLFBS Air Cleaner Enough?
Like FranBunny stated too, changing to a K&N element is done but I tried stock paper and the K&N element in mine and while trying to hold on at full throttle, cannot tell the difference
Well, then you used something different, I am talking about the Ventinator on the "S" bikes and the SE Ventilator.
Personally, I research what should be done and not half **** it. To each his own tho...cheers
The M8 brought something new to the the table, I wanted one. My last one below, stage two with a dyno too. Twinkie tho...*laffs. I do have more pics of my previous scoots and their mods should you be interested...*grinz
jfl330 (05-14-2020)
As OldMike said, the stock ventilator on the 114 will work just fine with a stage 2. Go with the K&N if you want to be re-oiling the filter all the time. That's about the only difference between the two elements other than a small amout of difference in flow. But not enough to make a huge difference in performance.
The following 2 users liked this post by Bowhunter8607:
FatBob2018 (05-15-2020),
OldMike (05-15-2020)
