2018+ Softail Models Breakout
Amazon Rack Installed
Old Mar 30, 2024 | 02:18 PM
1HD1C's Avatar
1HD1C
Originally Posted by JimGnitecki
So you can change from rack to backrest to only the docking points, right? But with this setup, you cannot have BOTH backrest and rack at the same time, right?
Jim G
yes, you cant run both at same time.. the givi trunk i used i have a backrest pad for but havent nstalled it yet
Old Apr 1, 2024 | 10:27 AM
cwsharp's Avatar
cwsharp
Probably helps with wheelies!
Old Apr 2, 2024 | 11:24 AM
Powermankw's Avatar
Powermankw
I've been looking for something I can Tay a bag on. I only ride solo and most stuff goes with 2 up. I don't need to hang it off the back. This way makes sense to lay your bag across on seat like you say... But I don't have that. There are rack to it on fender, but then need to lay sideways across hard bags. I don't really care for sissy bar, but that might be all... And those are generally 2 up again.
Old Apr 2, 2024 | 03:01 PM
JimGnitecki's Avatar
JimGnitecki
Although the sissybars are indeed desgined for "2-up" seats, by the time you put your luggage bag onto the passenger portion, in front of the sissy bar, you then get a backrest for yourself. Plus, the height of the passenger seat keeps the bag from touching any side saddle bags you might have, and also your fender paint.
See my posting on this topic at:
https://www.hdforums.com/forum/softa...-solution.html
Jim G
Jim G
Old Apr 2, 2024 | 04:28 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Sure you can toss a duffle across the passenger seat and drape it over onto the saddlebags. Nothing wrong with doing that.
About the only drawback to that is it can make getting into the saddlebags a little difficult with the duffle bag there.
Old Apr 2, 2024 | 06:24 PM
Powermankw's Avatar
Powermankw
Sure, but they are just plastic and I don't want to hose the finish. That is an obvious choice, but if I had a magic wand it would be a luggage rack type rack... Like on tour pack... That would extend over the hard bags a bit. Hummm... ****... I have seen the same type rack for tour packs for solo seats... I wonder if I could bolt a luggage rack to it just lay stuff across? That would not look get to, but I would only do this every now and then. I bet I could fab up my own type of rack. Like that just extended the length of clam shell openings on each side. Then if it's detachable like this topic one it would just put it on, strap my bag down, and go.
Old Apr 2, 2024 | 06:53 PM
Powermankw's Avatar
Powermankw
Jim G
Jim G
And I thought I wrote a lot... 😁. That's not an insult. Thank you! I actually agree with a lot of that reasoning. I've thought the same. I have dry bags from jet skis. I did think sissy bar and big dry bag would certainly work. I don't know if I will do the sissy bar thing. I don't want a passenger seat... But I do get the advantages and it is detachable. I like the fact it is a "stop" for a bag.
But I definitely love the bag. Duhh... What a great easy solution! Better than just a dry bag. And yes, plenty big enough. My large "day" pack is 36L. Most carry on are 1800-2000 ish ci. Any solution serving as a back rest seems like a no-brainer. I'm glad I said something, thank you for sharing that!
Old Apr 2, 2024 | 07:06 PM
JimGnitecki
Glad it helped you. That's what the forum is all about: helping each other find solutions.
Jim G
Old Apr 2, 2024 | 08:38 PM
foxtrapper's Avatar
foxtrapper
If you're traveling solo, a rack that sits where the passenger seat normally does might be the ticket for you. Again, quick release type. I think Harley does offer one of these, but otherwise they are available on the aftermarket. Put a board or such across it and drop the duffle on the board.
You can be interestingly creative with adding a backrest for you onto a mid-mount rack. You can even extend it somewhat rearward if you wish, or just use a bigger board (or counter top piece, etc).
I've seen it done where a piano hinge was used so the wings of the board could be folded in for narrow storage and use.
By all means, be creative!
Old Apr 2, 2024 | 09:25 PM
Powermankw's Avatar
Powermankw
Ya, I had to go look. From where a good back rest should be, to the end of the fender is 2 feet. So I could extend it more... But 2 foot for bag. And clam shell to clam shell is 17 inches across. So plenty of room to throw something on there. And yes, even securing a simple board with an end to stop it, lean on it. Ya, I like it. I'll get something together. Use a solo bracket like the OP, and get suitable platform for a suitable dry bag like show... Should be good to go.
I'm riding with a couple friends to OK in May. But a couple more friends are driving. So I said at worst I can have them take a bag. But this sounds like a good weekend trip to try it out and see how it works for me. My wife has a tri glide. That alone should get us through a weekend. But strapping a bag on is more than reasonable.
So thanks a bunch for all the help guys. I'll post up when I get it together.
Noodles107
Oct 31, 2023 01:40 PM
antman27
Sep 11, 2014 08:20 PM
steelerdude1
Jun 30, 2014 07:12 PM
mhill0732
Custom Models
Nov 16, 2013 01:24 PM
reddog8145
Jan 19, 2010 03:02 AM
