amp recomendation
Old 10-21-2014, 02:30 PM
paul1970's Avatar
paul1970
paul1970 is offline
Default amp recomendation
planning on putting crash bar speakers on my heritage, and using an ipod or I phone, the speakers I want to use say 4 ohm can anyone recommend a good budget amp & maybe a cord to keep phone or ipod charged
Old 10-22-2014, 12:34 PM
paul1970's Avatar
paul1970
paul1970 is offline
no help...... do I need to run amp at 2 ohms 4 ohms ? will a soundstream pn2.350 work with 4 ohm speakers
Old 10-22-2014, 01:07 PM
AAWAV's Avatar
AAWAV
AAWAV is offline
yes - almost any (if not all!) commonly used amps here on the forum for on the bike (Class D only!) will support 4 ohm (as well as 2 ohm). 2.350 will be fine.
going higher with load (so 4 ohm is higher than 2 ohm) is never an issue.... 8 ohm f.e. though will result in less max watts provided by the amp...
be careful not overpowering your speakers - you did not provide any details on the speakers you are intending to use... leaving the gain on the amp at a lower setting will help you accomplishing this
Old 10-22-2014, 01:25 PM
AAWAV's Avatar
AAWAV
AAWAV is offline
paul1970's Avatar
paul1970
paul1970 is offline
thank you sir, so for more volume I should go with 2 ohm speakers ? the speakers I have are rated at 250 watts 4 ohms, a good match for the soundstream or are there better suited amps
Old 10-22-2014, 01:31 PM
AAWAV's Avatar
AAWAV
AAWAV is offline
sorry about the triple post - 2 ohm will be better yes. keep in mind the Peak Watts is NOT what you need to look at - it is the RMS Watts...
In general, most installs for 2 speaker setup is RF PBR300x2.
the 2.350:
Picasso Nano Series 2-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 115 watts x 2 chan.
2 ohms: 175 watts x 2 chan.
DO NOT BRIDGE....
above specs are a bit overrated IMO but do not have the proof- prob. looking more at 90 ish and 130/140
running 10AWG powerlines is plenty - no need for 4 AWG as stated...
just make sure you start low with the gain depending on your speakers.
hate to see you blow up your tightly enclosed speakers (not a fan of the setup but understand your issue - no fairing)
Old 10-22-2014, 01:50 PM
paul1970's Avatar
paul1970
paul1970 is offline
I may go with the Rockford fosgate its got really good reviews, I did a hard bag conversion this year, so long term plan is to add 6x9 lids but for now just looking for some sound and somewhere to start
Old 10-22-2014, 02:19 PM
AAWAV's Avatar
AAWAV
AAWAV is offline
plan ahead - go with SS PN4.520 or (a bit better IMHO) the PA RZ4 (see my signature). just use front channels only for the time being...
saves you money/extra work/etc
sonicelec... sells it for 110
Old 10-22-2014, 02:34 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Sorry Sir I somehow missed your thread. . . but it looks like AAWAV got you covered.
Old 10-22-2014, 07:50 PM
paul1970's Avatar
paul1970
paul1970 is offline
thanks guys think im gonna order the 4 channel ss and give this a try
Quick Reply: amp recomendation
