New stuff is in.
Old 11-29-2014, 08:00 PM
Little Mike's Avatar
Little Mike
Little Mike is offline
These might help.
Old 11-30-2014, 01:53 AM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
If you say so Nutz that is more than good enough for me.
And thanx for that table Mike. That gives me some peace of mind that the bike won't melt underneath me while riding down the road.
Old 11-30-2014, 09:12 AM
dirtracin23
Originally Posted by UltraNutZ
Regardless, with that amp I would use 8ga and a 30A fuse at the battery. You always want your battery fuse to be smaller than that of your amp so it will blow first if there is an issue and will protect your bike's electrical system in addition to negating you having to pull the fairing off but instead simply pop the seat off to change a fuse.
I'm a little confused here. I have the inline fuse holder on the main hot wire @ the battery. Is there supposed to be another fuse on or installed near the amp. I have seen pictures of amps with fuses actually in the back of the amp near the inputs but this amp does not have any thing like that.
Don't laugh, I told you all I was "audio install" challenged.
Old 11-30-2014, 09:27 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
IF there is a fuse on/at the amp, you want a smaller rated fuse at the battery so it will protect your electrical system.
Old 11-30-2014, 09:36 AM
dirtracin23
OK, then would it to my advantage to install another inline fuse holder inside the fairing near the amp and then put a 30 amp fuse in it and a 25 amp fuse in the one under the seat? Or just have the one fuse holder under the seat?
UltraNutZ's Avatar
UltraNutZ
no sir.. just run with it.. don't over-complicate your install.
Old 11-30-2014, 09:54 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
LOL. . . What Nutz is simply saying is if your amp has a 40 amp fuse like the soundsteam for example. Your inline fuse to the battery need only be 30 amps.
Old 11-30-2014, 09:58 AM
dirtracin23
Gotcha.
Thanx!
Old 12-06-2014, 05:31 PM
dirtracin23
Gonna be at least another week before I can make any more progress. My dumb a$$ ordered the wrong size terminals for the Molex connectors.
No, I'm not blonde. Unless gray is a shade of blonde.
ScoobyDooHarley
Audio Systems
08-04-2018 04:21 PM
bowhunter13
2014-2023 Touring Models
08-14-2014 01:53 PM
bigreds1963ss
09-15-2013 08:32 PM
dowork08
04-30-2008 01:46 AM
chuckk01
04-02-2008 08:06 PM
Quick Reply: New stuff is in.
