Issues after 135_off.bin flash
Old Jul 12, 2015 | 09:00 AM
JMC22's Avatar
JMC22
Default Issues after 135_off.bin flash
2015 SGS, JL M400/4 amp, Focal K2 Power 165 KRC speakers only in the fairing.
After installing the new speakers and flashing to the 135_off.bin (which I have confirmed) I've encountered the following issues:
1) The amp sometimes doesn't wake up or sometimes shuts off when in low volume - if I crank the volume the amp will wake back up
2) I installed a Thundermax TracMax ABS wheel speed corrector as I have a 21" front wheel and after the flash I am getting an error code telling me there is a short in the ABS system, when disconnected it throws a different code since the front/rear wheels are more than 10% difference (here is the product -http://www.thunder-max.com/Products/TracMax.aspx)
Any ideas to to where either of these things are happening - the remote for the amp is wired into the cigarette lighter & the volt meter on the dash is reading 13 volts
Thanks
capnkirk
Audio Systems
Dec 15, 2018 12:49 PM
PostalRoadKing
Audio Systems
May 29, 2017 07:24 PM
just plain john
Audio Systems
Jun 18, 2016 08:31 AM
mflint1513
Audio Systems
Mar 25, 2013 08:07 PM
slip944
Jun 30, 2012 10:50 PM
