Audio upgrade on my FLHX. Your thoughts please.
  #61
Old 01-10-2017, 11:03 PM
iMAK79's Avatar
iMAK79
iMAK79 is offline
Originally Posted by angelrod
If you wanna keep your waterproof stereo Audio Processor is the answer
Initially I was thinking about keeping the stock head unit, but the extras you get with aftermarket head units like Bluetooth, Spotify, Pandora, and the additional adjustments and settings, convinced me to go for it, especially with the hand controls that are talking to the head unit.
  #62
Old 01-10-2017, 11:05 PM
iMAK79's Avatar
iMAK79
iMAK79 is offline
Originally Posted by Bertk
Nicely done!!!
Thank you mate, it's done with the great help from this forum and the knowledgeable members...
  #63
Old 01-11-2017, 12:09 AM
iMAK79's Avatar
iMAK79
iMAK79 is offline
Originally Posted by SBates08
Have you put your fairing cap back on yet? Looks like the amp may hit.
Originally Posted by slyedog
Always a blast thinking it will all work out, then spend a good hour wrestling the outer, to then realize you are a half inch or so off and back to square one. Op good luck. Hope it fits
Before cutting the corners of the tray, it was slightly touching the outer fairing, I stick paper mask tape on the inside of the fairing, attach it and loose tight the screws, remove it to see some scratches on the tape on the right side. I cut the corners and now it doesn't hit and the fairing goes on and attaches smoothly.
I'll be attaching the fairing for the coming Friday but will take it off again to install the Hawg Wired speaker grills.
  #64
Old 03-18-2018, 08:07 AM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
Mohammed,
I PM’d you!
  #65
Old 02-03-2019, 05:56 PM
ironman1120's Avatar
ironman1120
ironman1120 is offline
Stage III
Originally Posted by iMAK79
Before and after progress of the installation...
Before (Stock
After...
Speakers and head unit in place, figuring out how to mount the amp.
Speakers wrapped with polyfil.
Home made aluminum mounting tray in place...
Final steps and organizing the wiring...
Hoping you could provide the specs on this aluminum tray. I'm installing the same amp on my 2008 Streetglide and need to make one.
Thanks in advance!
  #66
Old 02-03-2019, 06:19 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,236 Likes on 1,000 Posts
Thanks in advance!
This amp tray is not on a Rushmore bike. You can cut your stock tray to make it fit.
  #67
Old 02-03-2019, 07:57 PM
5280Ruffian's Avatar
5280Ruffian
5280Ruffian is offline
I got an amp tray off eBay for ~$40. It worked great.
utz
Touring Parts
09-21-2015 07:42 AM
Dave102
Audio Systems
09-19-2014 09:44 AM
drtbkkar
Audio Systems
13
11-25-2013 11:12 AM
BrownSanta
Touring Parts
01-20-2013 10:30 PM
djack
12-20-2011 08:38 PM
Quick Reply: Audio upgrade on my FLHX. Your thoughts please.
