Cerwin vega b4
Just so you know, the b54 is discontinued. The diamond audio micro 4v2 is the sister amp of the b54. On paper, the 4v2 has a little better specs...we will see. Lol The b54 is still around at some places but are getting hard to come by. I just got a 4v2 from LL247 for a killer deal! Maybe send him a pm to see if he can help?
Originally Posted by LL247
Diamond has better internals as well.
I've read where folks say the Micro line has better internals, I've read where other say it's the exact same amp. I understand that the board, engineering design, etc. is the same as this happens with numerous amps but in neither side of this have I seen a bench test on both amps, or amp guts side by side. So if indeed the Micro has better internals (not sure which ones) etc. how does that translate to better sound from the same board design?
I've had both the B2 and the Micro2 V1, but unfortunately I did not have them at the same time to A/B them. I was impressed with the SQ of both.
AAWAV....where you at bro. We need some amp engineering talk here.
