help external speaker out into AUX
I purchased a Cobra 75 WX ST CB Radio with the intent of using the AUX input to my Sony MEX70-BT head unit as input from the external speaker plug on the unit. Upon reading the manual I see the following: "The eternal speaker should have 4-8 ohms impedance and be able to handle at least 4 watts." Do I need some sort of doohickey (technical term) in between the EXT speaker output and the AUX input?
Thanks in advance.
Thanks in advance.
The input impedance is way more than 8 ohms and should be fine. The audio output may be to much drive for the for the input of the amp inside your head unit. Just start out with the HU volume at the mid point, turn the CB volume to the lowest setting, open the Sq so you have some audio then slowly start turning up the volume on the CB till it sounds clean. Remember what the volume was on the CB and never turn it up any higher. Too much drive will blow the AUX amp input. Use the HU volume at any level you need. Just don't turn the CB up too much.
I decided to try buying a small external speaker - it was only $17. I hooked everything up and it sounds like it may be loud enough to hear on the road. My plan is to set it in the windshield bag. After some test runs with the bag open I will drill holes in the top of the bag to allow the sound out and cover with waterproof mesh. Obviously a step down in the Aux can be done because the Cobra speakers have an ear-bud output. However, those speakers are too big for me - and besides I don't want a speaker at all when headed into AUX. I like the idea of having the CB completely independent from the stereo. If I am interested in the CB I can mute the stereo if I hear something.
bteski
Audio Systems
04-30-2015 11:59 PM
mastery
12-19-2010 05:27 AM
