I see the default settings for the HPF dials but what is the default settings on he end? I received mine with the dials on the end set around 11oclock.. is this correct? I thought I read somewhere they should both be straight up in the 12 o'clock position?
thanks
Around 11 o'clock is correct for the default settings on the BT355.
The settings are extremely sensitive so unless you have the proper procedure from Biketronics to reset them don't move them
