JL Audio Fix 86
#52
Glad to hear that.
Dumb ?. When you go from say 1-20-3 to 1-21 or any other for that matter. Do you reset the radio (factory reset )each time.or you just update and move on..Harley website does not mention a reset after the update. .was wondering what other do after a update
Thanks
Thanks
#53
I will start to do a reset
All is good but I do notice the front sounds stronger than the rear when using fader. .Front and rear are identical setup.same amp and speakers. . Even use a oscilloscope for clipping to set amps...maybe the enclosure does this ? Any thoughts
Thanks for all the help...
UltraNutZ
Electrical/Lighting/Alarm
15
03-12-2013 09:35 AM
