DSP in HU vs External DSPs
Pick one or the other NOT BOTH! I'd suggest going with the one that gives you the most settings that YOU want to tune from. Just because an external DSP has a ton more settings and adjustability, the built in one may give you want you want. Try it first.
More settings doesn't always merit better sound.
If you have a HU like the 998 with all coaxial speakers, you might no benefit from an external DSP.
In the other hand if you are running all components, an external DSP and multiple amps to give every driver their own channel will give you more flexibility to tune the system and make it sound better.
