Rockford DSR1 Install Help
thats seems like a bad idea. The whole purpose of a sound processor is to tailor the sound to your liking. The bt355 is a filter. The dsr does the same thing, just user adjustable. I'd pick one or the other
while yes the dsp does a lot,,,if you have the flat signal to start with(from using the line leveler, which also makes the rca stuff plug and play), you might not have to use the extremes in the eq and mixing sections of the dsp in trying to compensate for the stock radio flash, thus allowing cleaner adjustments and less noise, which in turn would allow for more volume with less garbage.
one or the other is usually the choice, but if you already own both, it wouldn't hurt to try it out, you can always not use the LL if there is anything funky going on.
m
m
m
m
