CV B52 and Hertz MPX 165.3 amp settings advice needed
Going to be installing a set of Mille Pro’s on my 17 RG. Currently running stock HU and a CV B52 amp Looking for a good starting point with the amp settings for this setup.
Also, do these speakers sound better with some air? Should I run them without the pods?
Thank you for your help.
I was instructed by the powers to be on here to set gains at 24.5 volts. I don't recall what they said for crossover nor do I recall where I ended up setting mine. Ran mine with the stock pods and with the brackets and I think I preferred the brackets over the pods. This was on my SG though, not a RG.
Garrett
Garrett
CV B52 settings
Thanks for the input SSpeeDEMONSS. I'm going to try and get everything tuned tonight, doing it by ear since its all I know. Newb at this.
Can anyone offer up some advice that maybe has experience with this setup or these speakers in general on where I should be as far as amp settings?
Thanks in advance for any help you can give.
Yeah D. that's how I've done it, except the last time I added the SS TN 900 in my TP, then Baby Boy came over and used his electronics to give me a baseline. I still fine tuned it by ear. With 1 amp and 1 set of speakers its simple. Set your HU at 3/4 volume, then turn up amp volume till distortion creeps in, then back gains down a little, easy peasy. The best way is with bike running (more voltage) next best is with bike hooked to a charger. I always take a tooth pick and some white paint to mark where the gain **** is set, so you have a reference point, in case you continue to play with the tuning!
TexasD (03-27-2018)
Bunker
Audio Systems
07-18-2021 10:09 PM
WVFLHX
Audio Systems
03-14-2016 05:45 PM
