Getting a JL Audio JX400/4D to fit in 14+
Old 04-09-2018, 09:52 AM
heiner921's Avatar
heiner921
heiner921 is offline
Default Getting a JL Audio JX400/4D to fit in 14+
As the title says. I installed a jx400/4d in the fairing on my 15 sgs using the stock amp tray. It is a tight fit and I can get the outer fairing on the bike but its doesnt seal around the left mirror area. Anyone have this specific amp on their bike using the stock amp tray? I don't really wanna buy a whole different amp but will lif need be. Any way to make this fit better. I could probably scoot it closer to the gauges but that would put pressure on the connector for the speedo/tach. Exploring options before I reside to get the xd400/4v2 amp which is skinnier width wise so it will fit but the xD has the rca and all wire hook ups towards the outer fairinf so with that amp I feel I would put strain on those connections. TIA
Old 04-09-2018, 09:58 AM
haze324's Avatar
haze324
haze324 is offline
I use the XD400/4 all the time on your year bike. No issues.
Old 04-09-2018, 10:02 AM
heiner921's Avatar
heiner921
using stock amp tray? Have pics of mounting? How close to gauge connectors are you?
Old 04-09-2018, 10:17 AM
haze324's Avatar
haze324
haze324 is offline
yes stock tray. I don't have pics, but have done this install numerous times.
Old 04-09-2018, 10:21 AM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
Old 04-09-2018, 10:42 AM
heiner921's Avatar
heiner921
[QUOTE=InthewindMN;17258791]
Looks like your using both stock and after market amp tray.. that the v2 amp?
Old 04-09-2018, 10:45 AM
InthewindMN
That is the xd400/4v2 on just the stock amp tray. It’s mounted to a 1/4”x1” aluminum bar mounted to the radio.
Old 04-09-2018, 12:02 PM
heiner921's Avatar
heiner921
i see you have each speaker bridged to where 1 speaker is on channel 1 and 2 and the other is on channel 3 and 4 instead of bridging both across 1 and 2 channel. what does doing it the way you have it benefit from having both bridged across channel 1 and 2 as how mine are.
Old 04-09-2018, 01:11 PM
InthewindMN
[QUOTE=heiner921;17259123]i see you have each speaker bridged to where 1 speaker is on channel 1 and 2 and the other is on channel 3 and 4 instead of bridging both across 1 and 2 channel. what does doing it the way you have it benefit from having both bridged across channel 1 and 2 as how mine are.[/QUOTE
Im using the whole amp bridged to 200x2 @4ohm.
Old 04-09-2018, 02:46 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,236 Likes on 1,000 Posts
The way he has his speaker outs wired is the only way to run bridged. If your running your speaker outs on channel 1 and channel 2 then you're not running in bridged mode.
Quick Reply: Getting a JL Audio JX400/4D to fit in 14+
