bridge channels 3 and 4 and parallel the 6x9s Start at about 200 to the 6x9 and go from there. Get a SD 250 tonrun the horns. A DSP will really get you where you want it to sound. HU will be limited. You will be real happy with that set up.
I have not looked at the specs on that amp lately but I'm pretty sure u need to be at 4 ohm for bridged ops thus in order to bridge and parallel ur 6x9s would have to be 8 ohm.
I could use the KS 125.4 bridged to feed lid VO 6x9's giving each 250w.
The KS125.2 to the horns giving eack 75w.
Just need a descent 4ch to feed the PRV's in fairing and lowers.
You will not need to give each horn 75w unless you like your eardrums peeledd back and inside out hahaha. The PRVS will need 75w and above depending on what your looking for 100 makes them happy but they will take a lot more.
