Diamond Micro4v2 Correct RCA Input for Bridging
Originally Posted by FLYINGBROKE
This always make me scratch my head.to me for it to be stereo you would take front right y it to amp input front and rear channel and same for left .the way he has it is just like Diamond diagram which clearly says mono.anybody want to help me understand better
The amp when bridged is a mono output signal. So you are basically wiring a 4 channel amp as a higher power 2 channel amp.
If there was a input channel selector switch on the amp you could get by only using 2 RCA inputs to 2 channels without a rcaY and achieve the same results as the amp would combine the input channels internally.
