Cutting in and out
Old Apr 21, 2018 | 12:22 PM
cfave's Avatar
cfave
Default Cutting in and out
Went for a ride last night as well as this morning and noticed that my fairing speakers are cutting in and out. first the left then the right but not at the same time. As I was pulling in, the right speaker was staticy could it be my AWs or the Arc 600 connectors?
This doesnt do it while sitting in the garage, only while out on the road.
Old Apr 21, 2018 | 12:36 PM
Outkast6991's Avatar
Outkast6991
RCA's coming loose?
Old Apr 21, 2018 | 12:47 PM
Stuntmeat's Avatar
Stuntmeat
If your running the arc 600 it's probably the connector. I read posts about it a while back. If you put a little sideways tension on the connector it would probably help. I used a zip tie.
Old Apr 21, 2018 | 01:59 PM
cfave's Avatar
cfave
what did you tie it off to?
Old Apr 21, 2018 | 05:23 PM
Stuntmeat's Avatar
Stuntmeat
The power and ground wire.
Old Apr 21, 2018 | 09:30 PM
cfave's Avatar
cfave
It’s just in my fairing speakers my lowers seam fine. Fairing is channel 1/2 and lowers are 3/4
Old Apr 21, 2018 | 09:36 PM
InthewindMN's Avatar
InthewindMN
Does it cut out at low volume or just high volume?
Old Apr 21, 2018 | 09:40 PM
travelingypsye's Avatar
travelingypsye
If you have LL in play, switch the rca from front to lowers and see if any static/ cut out happens on the lowers. My guess it is the rca connection somewhere.
Old Apr 21, 2018 | 10:35 PM
cfave's Avatar
cfave
Noticed it at all volumes
Old Apr 21, 2018 | 10:37 PM
cfave's Avatar
cfave
No LLs Sony hu mex70 arc 6004 and DD aw/at with txo x-overs in fairing and Beyma in lowers
