New 8's
Yes, I need new 8's. After troubleshooting on my own, I tried I known good speaker on the wiring to the 8 that wasn't working, and the good speaker worked. I guess that means it's blown. So help me out, and I know we all have our own opinions....
I managed to get a refund for a defective product, so no I need something to fill the holes.
Must go low...50 hz or so, 4 ohm, can take 300+ watts. I'm not an expert, but the two that come to mind are the same 200L I had, or the GZ yellow baskets. Any other ideas?
What I experience, for a short time, yesterday was a midbass punch. I never really knew what people meant by that. It wasn't in the 50hz range. It was probably in the 80-90 hz range, and just seem to make the other speakers sound lower and better. It was pretty amazing.
I've never heard a bad word about Ground Zero yellow baskets. They just show 150 watts RMS. I wouldn't be completely opposed coax with a warm woofer in the 80 hz range.
With that power you may need to stay with a speaker that has a 95spl spec or higher in order to get good volume.
What do you guys think of the discontinued Pioneer TMS800 Pro. It's 96 SPL, and a huge frequency range. Max power at 700 watts each.
Here is my two cents on the subject. An 8 in the lid really doesn't have a lot of business playing in the 50 hz range. I think you need an 8 that is loud enough for riding speed and will maintain some thump. After hearing the GZ yellows, I think that is a very solid speaker for that application. Yes, the stinger bridged is probably a little too much power for them, but you can always turn the amp down a bit. I'd hit up slodsm, ask him what amp he's running on them and where his crossovers are set. Those are some of the best kid speakers I've heard yet. Next is a set of horns for the lids. Not sure where you are on that, but GZ, DD, Hertz all make good products for that application. Selecting the right 8 and horn will yield you some damn good results.
I don't know anything about the pioneer, and while I'm all about trying new products, I think there is a wide enough range that the forum has used other than that that can be used.
The 200L is a good option for lower bass but won't get up into the mid ranges as high as the yellow.
A hertz 200.1 is a loud good speaker but won't play low.
Rockville RM64 is a good choice also, but the power you have is too much for them. I've had them at 80 hz with good thump but now strong bass. More of a midrange speaker.
Crescendo UN8 is also another good choice. Won't provide as much on the lows but good clear mids.
If bass and volume is what you're looking for I think the yellow is your huckleberry
AD
AD
