Ground Zero GZCK200SPL Question
Old Mar 23, 2020 | 07:28 PM
Dhellyer's Avatar
Dhellyer
Default Ground Zero GZCK200SPL Question
I have 2 GZCK200SPL's, one in each bag. They are powered by a SD800.4S Evo (4ohm), and tuned with a DD DSI-2 sound processor. Each speaker is getting around 350 watts and the crossover is set at HP 65hz and LP 800hz. My question is, is it normal for these speakers to sound bad (distorted) at low volume? At first I thought they were blown but now I'm not sure because when I crank them up they sound good, with plenty of low end. Is it normal for the GZ's to sound distorted at low volume?
Old Mar 24, 2020 | 05:12 AM
marshallb's Avatar
marshallb
Deleted
Old Mar 24, 2020 | 06:55 PM
Dhellyer's Avatar
Dhellyer
Deleted. Trying to upload a file. They definitely are not blown.
Old Mar 24, 2020 | 07:30 PM
Ndfastln's Avatar
Ndfastln
Could be the gains are too high and you are picking up some floor noise, or possibly a ground loop issue. Is the amp grounded at the battery?
Old Mar 24, 2020 | 07:31 PM
Dhellyer's Avatar
Dhellyer
https://drive.google.com/file/d/1XNh9q-jxMdrUh5tOzpHPDLOJYVqEGLRn/view?usp=drivesdk
please excuse the pollen
Old Mar 24, 2020 | 07:41 PM
Dhellyer's Avatar
Dhellyer
amps are grounded at battery, set gains with DD1 and then turned down to desired output with VM.
Old Mar 24, 2020 | 08:17 PM
marshallb's Avatar
marshallb
Link isn’t connected for me. Is it working for others?
Old Mar 24, 2020 | 08:23 PM
Dhellyer's Avatar
Dhellyer
I wonder if one drive will work better?
Old Mar 24, 2020 | 08:39 PM
Dhellyer's Avatar
Dhellyer
https://1drv.ms/v/s!Anv3MtP0zSGwxFeTNiE0rfua2veS
Tool
gixxerkid3
Audio Systems
Aug 9, 2017 10:14 PM
InthewindMN
Audio Systems
Dec 9, 2016 08:31 PM
toddrick
Audio Systems
May 6, 2015 04:57 AM
jdgresham
2014-2024 Touring Models
Jan 28, 2015 09:19 PM
Anthony8858
May 3, 2009 04:23 PM
