Road Glide Inner Fairing Replacement Options
Anyone have any experience with replacing the inner fairing on a 2018 or similar year Road Glide to either a quad 6.5” setup or a full VooDoo Bikeworks 8.8” setup (https://voodoobikeworks.com/shop-onl...nner-fairing)?
I ordered a set of Dirty Bird Loud Pods to put a pair of Ground Zero 8” Red Baskets in. I fully intended to bond them on and repaint the full inner fairing, but let me just say they are far from “bolt on” and need a lot more body work than I was expecting based on the “bolt on” claims. I am also considering the Insane Asylum pods (http://www.insaneasylummotorsports.c...l#.XtOsaC9q2fA) but figured if I need to do all this body work for bond on options a full replacement may be just as cost effective and faster, so I wanted to check here for lessons learned or feedback.
If a quad 6.5” setup turns out to be a better option then I can certainly pivot and go with four 6.5” Red Baskets instead of the two 8”s. My biggest questions with the full replacements are if the full glove box assembly and speaker pods are reused or how the rear fairing support, turn signals and windshield mounting is handled.
