If Ultranuts system included independent tweets
Old 02-21-2013, 09:49 AM
Dew Me's Avatar
Dew Me
Dew Me is offline
Default If Ultranuts system included independent tweets
If someone (Me) was determined to replace two gauges with tweeters, which of these two choices would get the most highs to the rider at 75MPH?
A.) MM6501's in lowers with the tweeters mounted in batwing?
B.) MM651's in lowers with Focal tweets in batwing run off HK preamp?
Old 02-21-2013, 12:18 PM
Dragonfly2000's Avatar
Dragonfly2000
Dragonfly2000 is offline
If I read this correctly option A gives you a coaxial speaker in the lower, and another tweeter up top.
Option B gives you a Mid Driver down low and a tweeter up top.
Option A should give you more highs as there are twice as many tweeters. We have found being on a bike however the lower frequences are the first to be lost in the open air and on the road, leaving you primarily just highs anyway.
I'm also curious as to why the mix and matching of the brands? Either way if looking for purchasing the tweeters, I do have a set of them here from a bike that we put a set of KR2's in the lowers and didnt use the tweeters. I will attach a link to which ones they are.
http://www.crutchfield.com/S-IlQzjBD...r-165-KR2.html
I also have crossovers that are for a set of KRC's that will malke them work nicley. You will need to purchase the Harley dash plugs 75106-96A.
Old 02-21-2013, 01:02 PM
Dew Me's Avatar
Dew Me
Dew Me is offline
I'm sorry. I'll elaborate:
I'm bridging a SS Nano 4.520D, and wiring in series. The 2.7 ohm Polks are perfect for this. Batwing speakers will be MM651's no matter what. The MM6501 has almost identical specs but is component instead of coaxial. I decided on the Focal tweets b/c they are one of few than runs an a low enough RMS that they can run straight off the stereo (using the pre-amp)
So option A is MM651 (coaxial) and the tweeter portion of the MM6501 (component) mounted into the batwing. With the woofer (mid-woofer?) of the MM6501 mounted in the lower.
Option B is MM651 (coaxial) and a Focal tweeter in the batwing, and the same coaxial (MM651) mounted in lower.
So option B actually has more tweeters.
If I'm understanding you properly though I've been thinking about sound and wind wrong. I was thinking lows are more robust and they would cut through the wind better than highs. For that reason I was thinking the highs mounted in the lowers would have the most trouble getting to my ears. Are you saying I'll hear highs from the lowers better than I will hear the lows when at highway speeds?
Originally Posted by Dragonfly2000
I do have a set of them here from a bike that we put a set of KR2's in the lowers and didnt use the tweeters. I also have crossovers that are for a set of KRC's that will malke them work nicley. You will need to purchase the Harley dash plugs 75106-96A.
I'll PM you...
Old 02-21-2013, 01:17 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
I feel that either option would give you great separation and sound good.
Either way, whatever (bass and tweeters) is in the lowers is going wash when you get going. Sitting still is another sound altogether.
If I was a "tweetin" guy, I would go with option B
Old 02-21-2013, 05:19 PM
UltraNutZ's Avatar
UltraNutZ
here's a short clip with front speakers only.
This was done in a 30 x 30 garage with solid walls
I did not have any sound dampening material to hang on the garage door
Soundstream PN4.520D
Polk Audio MM651 fairing speakers only. This doesn't include the rears, faded all the way to the front
bass and treble flat on radio
ac/dc - you shook me all night long running from iPod 320kbs
119.8db averaged over 5 sessions. That's friking loud guys.... and best of all it was perfectly clear!
119.6, 120.2, 120.4, 120.2, 118.6
highest reading I got in 4 sessions with front and rear combined was 121.3db
https://www.dropbox.com/s/cd81x0wqif...6-58-33_44.mp4
Old 02-21-2013, 06:51 PM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
.That's a LOT of highs !! BASS is where it's at !.
May not be a world of difference either way. Would be interesting to see it both ways,........to see how it stacks up. It doesn't take a lot of highs on these systems.........
Old 02-21-2013, 06:53 PM
UltraNutZ's Avatar
UltraNutZ
I hear ya man.. I'm dying here.. CS told me Monday 3 days to ship the painted lids when I ordered. Talked to Bill today, he said it would be next week before they ship.
Got my speakers already and I picked up a package of 10 of these for quick connects.
Old 02-21-2013, 07:15 PM
GLACIERPEARL
Since I have 2 speakers in each bag, I needed the 4 wire connector, that's why I went with the Deutsch Connectors. Boy are they expensive, for what they are !! Almost $20 bucks a piece.
Old 02-21-2013, 07:17 PM
Dew Me's Avatar
Dew Me
Dew Me is offline
.BASS is where it's at !.
I've actually never been big on highs. Every system I ever built it was all about the bass. With this being my first bike with a stereo, I noticed right away it was the highs that suffered most. From what I think I know about highs I'm most afraid of highs not making it to my ear.
Old 02-22-2013, 06:12 AM
UltraNutZ's Avatar
UltraNutZ
Oh they'll make it to your ears... Especially those fairing speakers.
oc357
Audio Systems
15
03-09-2022 08:26 PM
Sarge4
06-20-2020 05:44 PM
Scooby1426
Audio Systems
05-23-2019 08:57 AM
bzmannn
Audio Systems
10-15-2018 07:33 AM
cash64
Audio Systems
14
09-23-2016 03:28 PM
Quick Reply: If Ultranuts system included independent tweets
