Speaker Cutting Out
Old Jun 23, 2013 | 05:40 PM
tpb857's Avatar
tpb857
Default Speaker Cutting Out
The bike is a 2012 CVO Street Glide, so I know that it is a different animal as far as the audio is concerned. The speaker in the left saddlebag lid works sometimes and doesn't work sometimes. It has a plug for the wires where it hooks up to the speaker. If I unplug it and plug it back in, it works again. If I shut it off and turn it back on, it doesn't work unless I unplug it and plug it back in again. I changed the connector and same thing. I tried a different speaker and the same thing. The connector to the rear speakers in the fairing is good. Just to cover all of the bases, I few weeks ago, I upgraded the sound system, but just in the front. I put a new amp in and new speakers for the fairing and the lowers. I don't thing that is the problem. The plug into the head unit is good. Could it be the head unit or any other ideas? Thanks.
Old Jun 23, 2013 | 06:08 PM
hdslam's Avatar
hdslam
Are the speakers you changed out the same ohms? If not, you have created an impedence problem, and the speakers will cut out because of problem it creates in the head unit. Was this happening prior to the swap? With the limited information provided, this would be the possible solution.
Old Jun 23, 2013 | 07:53 PM
yank721's Avatar
yank721
He changed the amp out as well so unless he matches the wrong amp and speakers up then the ohm load is fine being different then the back.
Outkast6991
Audio Systems
16
Oct 30, 2018 11:43 AM
Roadking69
Audio Systems
13
Oct 13, 2015 06:00 PM
CC Rainman
Audio Systems
Jul 6, 2013 03:02 PM
BschloSS
Audio Systems
26
Feb 18, 2013 08:13 PM
Akitakoi
Mar 31, 2009 10:43 PM
