SS PN4.520 heat Issues?
I recently installed a SS PN4.520 amp, Sony DSX-310BT head unit with Biketronics controller and Biketronics BT7P1 speakers w/polyfil. I have read from others with the same setup how after 30-40 minutes use in the garage tweaking with the gains the amp is cool to the touch. I have to say that mine is warmer than cool to the touch after 40 minutes of jamming and tweaking. I am using #8 gauge positive and negative cables looped through two ferrite cores and #16 gauge speaker wire. I had the ground hooked up to the triple tree originally and then moved it to the battery. After feeling how warm it was getting on the initial gain adjustment I started to monitor with an infrared pyrometer. The next day after moving the ground to the battery I took ambient temp readings and then ran it as hard as the previous day for approximately the equal amount of time. Here are the results:
Ground to triple tree - 130F-131F
Ambient temp in garage - 104F
Ground to Battery - 129F-130F
Are these temps something to be concerned about? The amp showed no signs of overheating or clipping. Interesting to note that there was little to no difference between the ground on the triple tree and battery.
On a side note, this setup really rocks. It is quite an improvement over the Biketronics BT480 amp and 6.5" Hertz Titans. The Biketronics amp may have put out a bit more raw power but it was never as crisp and clear as this SS amp. Thanks to all, especially Ultranutz for the recommendations and knowledge brought to the table.
ambient temp is for sure. :-)
remember you've got no cooling while sitting still. When you're moving, air is going up inside that fairing. But realistically, these temps are WELL within operating temps for these amps.
My PN2.350D mounted inside the tourpak though never gets hot and I've got it covered with a piece of trunk matching material to keep the wife's blingy crap from contacting the terminals on the amp.
This set up sure sounds awesome, I can't wait to get the 6X9's in the lids.
I just need to dial in the settings on the head unit now and I will be in business. I have the LPF and HPF settings on the head unit set at 80% with the slope at 1?. The DM+ Advanced is set to on as is the Dynamic Loudness. Does this sound about right? I know it is a matter of personal preference but just curious how others have this headunit set up.
i told you to run to battery since you're installing new and my experiences with the grounds up front on pre-06 bikes.
chunngle has this already installed and it's been running perfectly fine for him where it's grounded now so it's up to you where you want to ground the amp just make sure it's a good solid ground..
