FM static with rockford fosgate pbr300x4
you are correct, no static or FM reception issues with this amp. You need to go back and look at the plug that goes into the back of your radio to make sure it's plugged in all the way and that the connector hasn't seperated. Cheap connectors HD uses so that may be the issue.
very odd indeed. these amps do not cause FM issues.. look under the left side cover where your fusebox is. there you'll find a connection for the antenna as well. make sure it's snug, clean, and tight as well.
what bike is this? if a tourpak is present, also under the liner of the tourpak is yet another connection...
What kind of head unit do you run? Some off brands radios have horrible output and poor aftermarket antennas cause unanticipated problems as well, just thinking out loud for your bike. I noticed my hidden antenna did nothing for my bike other than waste my money and cause a headache--literally w the static and broken sound it gave!!!
stock head unit
there are at least 1000 posts/threads between audio and touring sections that would have saved you the trouble. :-)
Ultra--what do they say that words when read will save your thousands of hours worth of headaches! Or something like that-- if I would of only read here before I purchased and installed and suffered!!
Thanks for summing it up it was easy at least what I did was confirmed and I didn't have to worry official I was doing something wrong chasing my tail.
