most amps these days have both high level (speaker wire) and low level (RCA) inputs. You can use either or but not both on the same amp. I would suggest a PAC SNI-15 instead of the 35. The 15 is a direct 10:1 reduction whereas the 35 is variable and can be a pain to dial in with your gains also.
you won't want to turn them down, just leave them set as they are from the factory. The PAC adjustable adapters are set at 10:1 reduction which is pretty much widely used across the industry for these line level adapters.
Got this off the PAC website...
SNI-35 converts 2 to 40 watts per channel speaker level output into a pre-amp signal. Perfect when adding an amplifier to a factory or aftermarket radio. Great for getting an additional set of pre-amps outputs from a head unit equipped with only one set. • Fixed 10:1 conversion.
• Linear from 20-20,000Hz at +/- 5 dB, while maintaining signal phase.
• Isolates input and output circuits to prevent ground loop noise.
so any recommendations regarding the gain settings on the PAC-35....and how do the gains on the PAC affect setting the gains on the amp when using the test tone and a multimeter?
