amp grounding
Old Apr 27, 2014 | 08:52 PM
ridedaddy's Avatar
ridedaddy
Default amp grounding
Is it true that running a amp ground to the battery instead of using a chassis ground can cause a "white noise or light static" sound through speakers?
Old Apr 27, 2014 | 09:53 PM
acchd's Avatar
acchd
NO I've always grounded to battery grd and never had issues. Rockford also did a backstep recently and said to ground to battery ground.
http://www.rockfordfosgate.com/suppo...ew=1#knowledge
Old Apr 28, 2014 | 01:09 PM
UltraNutZ's Avatar
UltraNutZ
you have a LOT of factors that will cause this but the main two are ground loops and gains set too high. When you raise the gains, you elevate the floor noise of the amp to a condition to be heard.
If you're dealing with a ground loop, then odds are likely to be in your favor that it's not the ground wire going back to the battery but a poor ground up in the fairing for your other audio components.
MDT
Audio Systems
Feb 15, 2017 11:39 AM
SgtMic
Audio Systems
Feb 10, 2017 06:26 PM
wils5150
Audio Systems
Aug 21, 2016 07:12 AM
remerson
Audio Systems
Mar 27, 2014 11:05 AM
Hydroboy35th
May 2, 2011 05:53 AM
