pbr300x4
Ok if I use the sound stream with stock Hu would I use hi level input or rca
whichever you prefer. If you're going to use 4 channels and you have a SG then you have 2 choices.
1.) get the 4 pins from Harley and solder wires for the rear outputs of the head unit and run that into the rear input of the amp or
2.) get a PAC SNI-15, 2 short RCA cables, and 2 RCA "Y" adapters. connect the PAC to the stock head unit front speaker wires and then the y adapters to it, then the RCAs from the Y adapter to the inputs on the amp.
option 2 provides for no fader control but on your SG the fader is not active anyways. If you go option 1, then you have bring the bike to HD and have them flash the fader active for you either before or after you do the install.
smittydog27
Audio Systems
Dec 12, 2014 02:55 PM
