Cough on upper throttle range
Check the float and float needle, is this a sudden issue or a progressive issue? If it is sudden then maybe you have something in the tank causing the issue ( or not enough of something *cough* fuel *cough*) maybe there is an obstruction. Have you down anything to the carb, double-check your work, maybe you pinched the diaphragm. Definitely check the needle jet, it could have been reinstalled upside-down if you had the emulsion tube out when you did the main jet.
A sneeze or cough, is the sign of a lean condition.
Petcock, float level(doubt that), or perhaps a tear in the vacuum piston.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I am 99.99% sure it's not the Piston I triple checked it and was super careful reinstallig it. The needle doesnt sit fully if the emulsion is in upside down.
i thought it may have been an intake leak but I havent touched it, and I wasnt a similar symptom before. Unless I jarred the manifold putting thecarb or pipes on.
It only happens, and it happens the same point in the opening of throttle every time.
i havent taken it on the road because once I hit that point in that throttle where it starts coughing if I hold it there, or open it more, the engine dies.
I'm using the stock needle, no washers. I guess my next step is trying to raise the needle up or buying an aftermarket needle-which I've read that doesn't give you as much fuel as the washer option does.
diddlyd
Carburetor Related
12-19-2015 11:17 PM
