Carburetor spit gas and smelled strong of gas, after start up this afternoon So parked bike...
thoughts?
Had rebuild two years ago might it be time again?
a sure cure for a needle that wont seat properly is to take it out take some 0000 steel wool take a small wad place it in the hole an spin it around with a small pocket screw driver clean the seat real good with carb cleaner install a OEM harley needle it has 4 sides, and set it according to manual, dont use a three sided needle , not reliable, as i found out on my 79 keihin carb, it cured my problem and runs great. Ride safe , Art
