S&S Shorty Carb rejetting
Hope to get some assistance on this one.
Having a S&S 103" with a S&S Shorty Carb, i have now got some trouble with it after changing my camshaft.
It was equipped with an S&S 563 cam when i got it, and i have changed it to a Andrews Ev72 cam due to cam and lifter wear on the old one.
Cam comparison table:
Intake Open/Close Exhaust Open/Close Intake ExhaustIntakeExhaustValve lift
Cam1: S&S 563 -Engine:1984> 10,5:1 > - Intake Open/Close: 32⁰/64⁰Exhaust Open/Close: 64⁰/32⁰ - Intake/Exhaust Dur: 276⁰/276⁰ - Lift @ TDC ╪ Intake/Exhaust: 0,250″/0,220″ - Valve lift: 0,561″
Cam2: Andrews EV72 84-99 EVO Intake Open/Close:30⁰/54⁰ Exhaust Open/Close: 64⁰/32⁰ - Intake/Exhaust Dur:264⁰268⁰ - Lift @ TDC ╪ Intake/Exhaust:0,249″0,250″ - Valve lift:0,560″
Got the cam and ignition timing right, and i have tryed just about everything except ripping out the carb to check the Intermediate an main jet.
When starting, it sneezes in the carb AND backfires sometimes, but reving the engine it chokes unless i have got some 2000 or more revs.
Looking at the cam specs, my first thougt with this behavior is to decrease the Intermediate and main jet.
Any advice/thougts ?
I’m no expert on Harleys and never had a bike with an S&S carb. But been doing carbs on cars for years.
Your newer cam looks milder than the old one, with less overlap. I’d start by leaning out the slow jet(or whatever S&S calls theirs ) and lean out the idle mixture screw. I wouldn’t change the main till you get the idle and part throttle running right, but you very well may have to lean that out too. JMO
Sneezing/popping from the carb can be lean, and/or retarded timing.
A dyno tune would cure both.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
