S&S Super B with Superbowl (accelerator pump) rebuild kit
I've got a super b fitted with the aftermarket super bowl (accelerator pump). It's pretty sticky when trying to adjust the idle speed so i am looking for a rebuild kit. Been having trouble sourcing one, so i am hoping someone has seen one out there or knows whether the diaphragm for a super E/G would fit.
Thanks!
Thanks!
Amazon has the Super B rebuiild kit The Bendix Accelerator Pump rebuild can be sourced http://www.vtwinmfg.com/webapp/wcs/s...ductId=3308710
Having problem with the idle speed look at where the butterfly shaft goes through the carb body. On the B the brass throttle shaft and the holes in the body tend to wear out particularly on the side where the cable connects, it'll suck air making the idle erratic. Warm the bike up and at an idle take a can of brake clean and give a little shot at the shaft, you'll know if that's your problem.
Nothing else wears out on one. Love that carb, worn out a few of them.
tar_snake (11-16-2018)
awstunn
05-03-2013 07:37 AM
