Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Stage 1 download
Old 09-29-2008, 09:10 AM
kraa26's Avatar
kraa26
kraa26 is offline
Default Stage 1 download
I know many of you had your harley's a long time.. and proably could help me answer this.
What is the stage 1 download?
Who downloads it ? Service?
Is it worth doing on a 08 roadking classic?
Just wondering options here. To see what I should and shouldn't do.. that doesn't cost too much.
Old 09-29-2008, 07:30 PM
Hounds2's Avatar
Hounds2
Hounds2 is offline
mine cost 150 bucks....the HD dealer has to download it for you...from what i gather it basically sets up a richer map taking into consideration your pipes and air cleaner. i have a basically stock 07 fxd. i put screaming eagle street legal exhaust and a k&n oem replacement air filter. ( i like K&N). anyway, my bike ran a bit lean from the time i bought it. putting the pipes and aircleaner made it no better or worse. i had the download done and it seems to run better and a bit richer too...before the download my plugs were pretty tan all over and a white on the tip. with the download my plugs are dark except the tip which is tan. i think its worth the money. however, even though the new harleys run lean i doubt that it is lean enough to hurt anything. to me it was cheaper and made more sense than screwing with a pc III or something. if i were really into souping my bike up and wanted to be able to tinker with it i would probably go with something external but not nearly stock as i am..good luck
Old 09-29-2008, 07:36 PM
jkoch09ultra's Avatar
jkoch09ultra
jkoch09ultra is offline
Put the stage 1 download on my 09 Ultra. Really woke it up. Great performance increase over stock. Also have Rush pipes and SE air cleaner.
Old 09-30-2008, 08:12 AM
mestude's Avatar
mestude
mestude is offline
Default i have the same question
im thinking the same question for my '07 RG.. i have a stock set up, will the "stage 1" benefit me in any way with it being stk...and if i do the download, and then add later some slip ons and and A/C kit, will they have to re-do the "stage 1"...
Old 10-02-2008, 06:17 PM
ashenfang's Avatar
ashenfang
ashenfang is offline
You "can" do the download before putting anything on your bike, but you might foul plugs from an overly rich condition. The download is a one-time thing. Regardless of what you put on the bike now or later. I had the download done as well. I also noticed an increase in performance, well worth the money.
Old 10-03-2008, 05:49 PM
09SERG's Avatar
09SERG
09SERG is offline
I thought we had to buy a SERT to do a stage 1 on 07 and later Harleys am I wrong
Old 10-04-2008, 06:49 AM
jkoch09ultra
Wrong 09SERG. I do not have SERT and did the stage 1 download. Dealer just installs if. Then works later with SERT or PCIII or any other tuner you may or may not get in the future.
Old 10-04-2008, 05:27 PM
bigoscycles's Avatar
bigoscycles
bigoscycles is offline
You don't have to have the SERT. Stage 1 is pretty basic and the dealer can do it.
Old 10-05-2008, 12:58 AM
fabricatorfbf's Avatar
fabricatorfbf
fabricatorfbf is offline
Default stage 1
You all left out an important benifit to a stage 1 download. It raises your rev limiter and is very benificial for that extra rpm when screwing around!
SDMF
04-02-2016 06:50 AM
BlockHead96
10-29-2008 07:39 PM
Conehead
09-08-2008 09:47 PM
srigas
Exhaust System Topics
04-12-2007 10:35 PM
Loch
05-26-2005 12:12 PM
Quick Reply: Stage 1 download
