securing a seat question..
Old Jun 16, 2020 | 06:27 PM
ARNAV's Avatar
ARNAV
Default securing a seat question..
Hello,
As you can see in the pictures, that's an exotic crocodile leather seat that I got. It is not secured yet, so I'm looking for some advice on how to safely secure it.
At the front of this seat, I have the little metal plate that should slide underneath another fixed plate... which does not exist. Should the fixed plate be welded to the frame? or is there a manufactured part that goes there that I should use?
At the back of the seat, there are 2 bolt holes. There is nothing on the rear fender so do I need to drill two holes and use bolts that are fixed on the seat side? if yes, how can I secure them underneath the fender, as the access there isn't easy? But if I leave two bolts fixed on the fender side, then how should I secure them to the seat?...
Also, the white coating underneath the seat is so soft like foam board, any ideas what material should I spray on it to make it still flexible but more resistant?
Thanks for advising!
Old Jun 16, 2020 | 06:51 PM
RANGER73's Avatar
RANGER73
Wrong seat for your year and model. Those holes are to add a passenger seat. Or
there's a bracket that has holes that slip over fixed fender bolts that you don't have either.
But as I don't know wtf year or model your bike is I can't help you anymore than that.
Old Jun 17, 2020 | 02:24 PM
ARNAV's Avatar
ARNAV
It's a custom bike, there is no specific year and model and it needs to be customized.
Old Jun 17, 2020 | 06:45 PM
RANGER73's Avatar
RANGER73
Then If you know that why ask?
Old Jun 18, 2020 | 09:09 PM
ARNAV's Avatar
ARNAV
I know that it needs to be customized, but this is what I am asking - how to secure it safely and conveniently?
Old Jun 22, 2020 | 11:26 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Looks like a LePera seat the was reupolstered and fits a Superglide frame from 70-82 but I can't see the rear side mounts that go to the frame on the Superglide...
Old Apr 26, 2021 | 09:51 PM
Bob Z.'s Avatar
Bob Z.
I have the rear of mine secured with industrial strength velcro, and before that I had a rubber grommet in the fender hole and a pin on the seat bottom - both were fine and looked nice since they kept the fender clean.
ange d mange
EVO
Sep 22, 2016 04:52 PM
kozy22
Feb 7, 2015 09:04 PM
pipeyeti
Oct 28, 2013 11:05 PM
bikerlaw
Feb 7, 2011 07:01 AM
pauletich
Jul 6, 2007 09:20 AM
