tp engineering 107
Old Feb 21, 2010 | 09:20 PM
drd21968's Avatar
drd21968
Angry tp engineering 107
i have a 107 tp engineering motor with a oil belching problem if it sits.normally, a easy fix.i first send the oil pump to tp to check the ball and seat that prevents this from happening.i get it back ,same problem.send it back,re install,still happens.they ask if i used any terflon tape that could be in oil,no.do i have an evo filter not a twin cam,yes.is my oil level correct,yes.i have now changed the oil and filter 4 times.frustrated i order a new pump,oil tank,replace the oil lines,install a crank case breather.have a bike shop install another piece in the motor they suspected to be the problem.checked gaskets to make sure thier right.problem still there.after five consecutive oil changes,new oil pump,lines ,tank,on a 6000 mile engine tp says my problem is debris in my oil.this is the cleanest oil,no metal,no gunk,its so clean you can see the floor perfect when it shoots it out the breather.i can re seat the ball with air pressure.i think i will install a ss pump.the problem is with the oil pump ball and spring.has anyone else experienced this problem thanks
Old Feb 22, 2010 | 10:12 PM
Puzzled's Avatar
Puzzled
I've had this with a very early 100" RT motor and a 113" TP. Both were resolved with an updated oil pump assembly.
Just for grins make certain the return line to the oil tank is the return port. I had a 124" TP here that was spewing oil from the head brathers. I eventually (after checking everything else) traced it to a bad return line in the tank. The internal line had broken off in the tank not allowing the oil to return to the tank.
Old Aug 25, 2018 | 08:29 PM
Isaiah Schenk's Avatar
Isaiah Schenk
Stage I
Default Tp motor oil change
I was wondering about you oil changing how do you flush the oil out of the motor i only can change the oil from the tank
Old Aug 25, 2018 | 11:13 PM
FastHarley's Avatar
FastHarley
Former Sponsor
I have a worked over 113CI TP and have experienced no such problem.
Old Sep 1, 2018 | 09:12 PM
Max Headflow's Avatar
Max Headflow
This is a possibility. You diagnosis is wrong, I suspect. If the standpipe in the tank broken off, Oil can back flow from the return line to the motor. Simple check. Remove the oil return line from oil tank. After a short while oil dribbling out of the tanks should stop.
Old Sep 4, 2018 | 05:44 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
TP engines did not have a history of that, as far as I know.
On most any gravity drain oil tank, the crankcase will build with oil after even 2 weeks, +/-, w/o being in operation.
We have many calls in the spring of each year regarding oil spitting from the breathers.
A dirty trick would be to have them bring it in, just to run up a work order on them, but we instead, we explain, and they appreciate the honesty, which has been a cornerstone of our 30 plus years in business.
Scott
pilot1996
Oil Archive (no new posts)
Apr 25, 2016 06:20 PM
milkman
Aug 12, 2011 02:33 PM
rad131313
Feb 28, 2011 02:49 PM
hdgrandaddy
Jul 20, 2010 07:12 PM
lebert
May 29, 2010 10:17 PM
