new build
Old Oct 15, 2012 | 10:11 AM
wammerjammer's Avatar
wammerjammer
Default new build
can anyone give me a hand . i have a santee ridgid with ultima 80 ci and ultima 6 speed LSD tranny it came with a tranny pully my question is what rear pully and how many teeth for rear .most all i read says use softail parts for set up does that include belts and pullys? i have spent a fortune on e bay buying belts and pullys that dont match up. i read use a 1 1'8 belt but how many teeth on the belt because i do know fifferent belt teeth fit on pully's differently as far as spacing goes any help appreciated i wanna ride this thing and this is my hold up
Dave
Old Oct 18, 2012 | 09:43 AM
misfitJason's Avatar
misfitJason
I do not have an answer for the size of belt. I would think it would have to be a custom length. If you would like to figure out gear ratios baker has a gear calculator on their website.
Old Oct 18, 2012 | 10:12 AM
misfitJason
O here it is. It depends on what year components you are using
86-92 132 tooth belt for 32 trans 70 final
93 128 tooth 32 61
95-96 130 32 65
97-99 130 32 65
Old Oct 20, 2012 | 09:34 AM
wammerjammer
Default belt
thanks Misfit
Old Oct 30, 2012 | 01:50 AM
rquest's Avatar
rquest
Springers rule!
Old Oct 30, 2012 | 08:27 AM
wammerjammer
Default belt
yes i do like springers also woohoo
Old Dec 27, 2012 | 10:16 PM
TwiZted Biker's Avatar
TwiZted Biker
Dave
Use this chart to figure what you need . Where you need to pay attention is the hole size on pulley so know what year pulley to buy there is a difference . The 1999 and back wheels had a 2" dia lip the pulley sits on and the 2000 and later wheels have a 2-1/4" lip . Now it gets entertaining the standard older softtail used a 1 1/2" wide 70 tooth pulley on the rear and I think a 132 tooth belt . The later bikes have a 66 tooth rear pulley so of course the belt is shorter . The tooth profile or size is the same on all the belts only differences are width & lengths .
This chart will let figure the sizes and belt length without all the guessing . Pay attention to the ratio too , check a factory manual for the stock ratio and stay close with that 6 speed or you'll have issues .
gmcz7155
Jun 4, 2018 06:26 PM
TaterBall
May 22, 2012 09:56 AM
quigley
Jun 21, 2008 06:49 PM
roadtrash56
Jan 31, 2008 11:06 PM
77Tulsa
Aug 3, 2007 10:09 PM
