Boy did I mess up today
Installed my cams. Everything went flawlessly UNTIL I tightened my tappet covers. The ball end of my hex( Ecklind brand us made btw)broke off on the inner front tappet cover. Didn't even tighten too hard as I had cut it off and put in a 3/16 socket so I could tq to 100 in lbs.I should have let it be but oh no not me. I think I better fix it now or next time I am screwed. I try to no avail to get the bolt to turn back out. No go. Only alternative is chisel head off and pull rest out with vise grips. Chiseled it off and no damage to anything but it broke deep enough that I couldn't get it out. Now I only have 3 with a prayer that rtv will help seal that corner. Also hope no shavings got anywhere in my desperate attempt at removal. I covered with rags, shop vac,and blew all out I could. Will finish tomorrow and change oil immediately after I get it warmed up. Hopefully it will not leak and I can figure out a solution some day or If I big bore will get it fixed then. Moral is sometimes your own perfection can cause you nothing but grief and struggle.
Ecklind Allen's haven't let me down yet. I keep a set T handles in my tool bag for every day use(not ball end though). I only use ball end keys after it's broken loose(if possible), and only to seat the bolt. I have other tools for breaking them free, or applying torque. When you do break a ball off, a good magnet, and sometimes a jewelers screwdriver or a pick, will go a long way to preventing damaging the bolt. I've learned that the hard way.
It sucks, but it happens.
Chase
Chase
That so blows Man, sad to hear indeed!
Could have been worse. You could have went for a swim on a vacation in some exotic 3rd world river and picked up some ******** eating bacteria with no cure!
Well, now, hoping none of your shavings got in there like you said, you have something to fix. Don't let it get you down, it's only castles burning...
I think it will be fine. If not I have a winter project. There is no other way to torque those inner bolts than a ball hex. I torque nazied myself. If it stays sealed up I will likely leave it till it does leak or if I ever go for more cubes I'll retap it. Think I'll spring for a set of sk ball hex sockets for next time.
