Great Bike Gear relo kit and Leather pro install
Figured I'd start the next/last thread of winter modifications.
Jdisme and some of the others were able to help out with the GBG relocation kit, the instructions are relatively simple but as always until you get in there you just don't know what you're in for.
In my case since I'm also going to be installing my Leather Pro retro saddlebags I took this opportunity to pull the inside fender bracket.
In the case of the later model Dyna's, the bracket is only threaded on one end. The bolt that goes through the other end threads into the turn signals. So if you're going to mount the saddlebags you not only require the plate/signal relocation kit but also the Harley bracket kit for sissy bar's and such which is another $69. Suede was kind enough to source just the brackets for me, about $16 each plus shipping.
I decided I was opposed to this on philosophical grounds, Garry at LP also mentions that a person could tap threads into the stock sleeve so that's what I decided to do.
First I jacked up the bike prior to unbolting the bottoms of the shocks so that the rear wheel was out of the way for wiring. Then unplugged the wires located below the seat and pull them through the fender. Grimy!
This is the bracket sleeve that bolts into the turn signal, not threaded
Didn't realize that when I took those brackets off the fender would fall!
Turn signal dangling
In for a penny in for a pound. I don't own a tap set but our shop at work does thankfully.
Perfect threads!
I'm going to remove the reflector, and finish/document the rest of the install tomorrow. Any tips or tricks are always appreciated!
Perfect threads!
Just a heads up, the fender will fall when you remove the fender support brackets
Well, since you've got the fender just sitting there you might as well get some soap and water and wash the inside, always better to work on clean stuff
Those reflectors come off easy on the rails and the sliders, dental floss, zip-zang you're done.
Looking great!
Looking great!
Robby, thanks for this write-up. Lol, I was too close to my situation. I was looking to get the hardware out that the PO had use to mount my Viking bags, and he mounted one of them with the bolt head inside the fender, so I was thinking my only option was to wait until I got my new tires on before that could be fixed. I didn't even think about removing the bottom shock mount. I guess I'll be able to take care of it prior, haha.
Looking great!
Looking great!
Definitely going to clean it all up, but that rear reflector is giving me grief
As far as tapping the holes in those brackets, if I remember correctly I think that piece is pressed in.. (At least mine was) I think I broke mine loose when tightening it and ended up putting a nut on the backside. If the same happens to you just make sure you'll have clearance between the side of the tire and the bolt/nut. You'll love those bags man, also do yourself a favor and put a little Chapstick in the female side of the buttons, it will make snapping/ unsnapping much easier... I broke the rivets on both my rear buttons before I figured that out haha
