Switchback throttle
Do I just have a high compression engine and/or a high power-to-weight ratio causing this or??? There also seems to be very little resistance to twisting the throttle when compared to other bikes I've ridden (metric bikes). Any thoughts or suggestions?
Thanks,
Inspectorbill
On your clutch cable there is a rubber boot. Slide it down and it will expose the adjustment nuts. When you adjust the cable you should see gap widen where the lever meets the housing, similar to when the gap gets bigger when you pull the lever. Do not adjust it too much or you could risk the clutch not fully disengaging when you release the lever. That can cause the bike to move in neutral and wear out the clutch plates faster.
Also, your throttle assembly consists of two cables, a throttle cable and a idle cable. While sitting on your bike looking at the throttle housing you'll see the two cables. The one furthest away from you (Closest to the brake lever) is the throttle cable. The cable closest to you is the idle cable.
The idle cable should be tight (no play) so the accelerator can return to the 0 position (idle) without issue. The throttle cable can be adjusted with a little play if you want so the throttle comes on a little later but remember the throttle position goes from 0 (idle) to 99 (Wide Open). Once you hit 1+ the bikes going to move so this probably won't help anyways.
One other option: It might just be easier to learn to hold on.
Good Luck!
