Need help finding a part
I have a 2011 harley DYNA FXDC.... I was adding some stuff to my bike and needed to pull off the fuse box cover. When I go to put it back on it does not lock in again. My friend told me that maybe the rubber pieces are old and need to be replaced. Any suggestions please???? If needed I would buy new rubber pieces but don't know where to find and or how to install.
The rubber grommets for my fuse box are still in good shape after 9 years, if we're talking about the same part.
The cover doesn't really lock on, it's just a squeeze fit. It's a very easy job to replace, but post up if you have a problem.
You can go to a dealer or find them on this:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Ronnies is a good source for looking up stock parts. I like St. Charles as well, it will give you screw/bolt sizes that Ronnies doesn't.
http://www.stcharlesharleydavidson.c...partfinder.htm
