need help with forks
Old Feb 17, 2008 | 01:51 AM
billyboy890's Avatar
billyboy890
Default need help with forks
l need to take the dust covers off the forks and have noticed a notch just below them do l insert a screwdriver and twist and they should pop up or is there a diferent way to it,its a 02 dyna lowrider
any help you guys can give much appreciated
Old Feb 17, 2008 | 02:12 AM
Azgunner's Avatar
Azgunner
Default RE: need help with forks
You can start there, but I'd LIGHTLY tap w/ a std. screwdriver & work your way around the cover to get them off. It's very easy to put dings on the edges of them if you're not real careful.
Old Feb 17, 2008 | 02:16 AM
billyboy890
thanks Az will try it later on this morning and fingers crossed it will work
jordanball33
Mar 24, 2013 10:29 PM
p8nter
"The Florida Crew"
21
Jan 16, 2010 08:57 AM
DGFIRONWORKS
Jul 23, 2006 10:31 AM
