Lazarus Project: 2012
  #441
Old 09-28-2016, 10:37 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,750 Likes on 3,962 Posts
An update on the Arlen Ness Big Brake rotor caliper bracket revision; Stephen from Arlen Ness just called and the new 02-972-1 caliper brackets are back on the shelf so I ordered the new version to replace my current bracket... $50...
  #442
Old 09-28-2016, 12:52 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
I will have to call and ask for two for my sportster. Thank you sir!
  #443
Old 09-29-2016, 09:51 PM
cvaria's Avatar
cvaria
cvaria is offline
Default removed tires...
tires removed
broken dreams... Rear, (180/60-17, Bias Ply, 17, Tubeless, 75, V $100 + shipping)
  #444
Old 09-29-2016, 10:11 PM
cvaria's Avatar
cvaria
cvaria is offline
Default put the bike on the ground and added locking detachable hardware...
Put the old tire back on the rear (so sad)... and to the bike off the fear lift. going to take it out tomorrow.
wet from me washing off the various grease and nonsense i got all over it over the past weeks of work.
added the locking hardware to the detachable sissy bar that randomly appeared on the bike and i never mentioned.
Parts used: 90300086
Locking H-D Detachables Latch Kit- http://www.harley-davidson.com/store...-90300047#tabs
locked down...
  #445
Old 09-30-2016, 08:54 AM
F86's Avatar
F86
F86 is offline
Well, that's the best news of the day so far!
cvaria (09-30-2016)
  #446
Old 09-30-2016, 06:15 PM
cvaria's Avatar
cvaria
cvaria is offline
took the bike out and seems like the gear shift lever doesn't want to come back to the "ready" position. did some quick forum digging and it looks like i need to clean the the filth and corrosion from the shaft by the peg. thoughts?
either way, i'll address it when the new shift linkage rod gets here next week
  #447
Old 09-30-2016, 06:22 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Yeah, disassemble/clean/lube the whole shifter lever and linkage. It all looks really dry.
  #448
Old 09-30-2016, 06:35 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Mind blown by BikeBandit.com
i was looking at the tires sitting there and and said fk it... i'm going to call Bikebandit and tell the truth and hope they approve the return of the rear... THEY DID! since i had put no miles they okayed the return! free shipping
and the they set me up with the 180/55/18 i need for the new wheel and price matched jake wilson for $176 vs the $208 they were charging.
outstanding... customer for life.
http://www.bikebandit.com/
  #449
Old 09-30-2016, 06:37 PM
cvaria's Avatar
cvaria
cvaria is offline
what do you use to lube it? anti-seize?
  #450
Old 09-30-2016, 06:45 PM
cggorman's Avatar
cggorman
cggorman is offline
No. Anti-seize is actually a pretty poor low pressure lube. It's got a lot of metal in it and is gritty.
I use a high pressure grease. Lithium grease, bearing grease, etc.
You my also want to check the end play on the lever shaft. There should be a few thousandths end play. Loosen the spline to adjust.
For linkage systems like this, I like to test/adjust one joint at a time to help eliminate problems. Take off the linkage and ensure both levers work freely and then try the ball joints on the linkage.
cvaria (09-30-2016)
Quick Reply: Lazarus Project: 2012
