08 Speedo Problem
Old Sep 24, 2016 | 01:35 PM
boarder8135's Avatar
boarder8135
4th Gear
Default 08 Speedo Problem
This is a weird one and I have done research and found nothing on it yet.
The problem is that the speedo that I currently have does not turn on at all. Speedo needle not working, the light not coming on, and the odometer isn't working at all. The weird thing is that I get the "Neutral" and signal lights and all that work. The auto cancel does work as well.
I'm just scratching my head on where to locate where its going wrong
I have had my buddy test the wires where it plugs into the speedo and everything seemed fine. Also I had the speedo replaced with a newer model since when I bought the bike it did the same thing and that didn't solve the problem.
I'm just wondering if I need a new key ignition or what, and I really don't want to pull wires out of the frame since they are pretty tight in there.
Any suggestions would help!
Thanks
Old Sep 24, 2016 | 02:16 PM
boarder8135
4th Gear
I also did check the fuses
Ryan Lee Brasher
Electrical/Lighting/Alarm
Jun 24, 2014 09:07 PM
Harvey2013!
Jan 9, 2014 01:37 AM
cgtrigg
Sep 25, 2012 01:22 PM
hdwillow
Jun 27, 2007 12:08 AM
saltlick
May 16, 2007 10:08 PM
