SB handle 75 mph and above?
Does you SB smooth out at higher speeds 5th and 6th gears, 75, 80, 90 mph?
Just how fast will it go?
http://www.putfile.com/pic.php?img=5472863
RE: SB handle 75 mph and above?
i have an '07 and i gotta tell yah, it was pretty smooth when i had her up there the other day.... i took off at a standstill and had her up to about 100mph in just seconds and she was purring like a kitten and as stable as steel ....and i had room to spare in 6th gear
The bike does just fine at speed,seems to run out ofsteam at about a hundred and twelve in sixth gear,never have tried top speed in fifth gear,might be faster than sixth.
Ona run back from the Ohio Valley last fall I made it from the Harley shop in Pelham to Mobile in three hours flat with two gas stops,two hundred and fourty miles.
Good Luck
Tom
Good Luck
Tom
ORIGINAL: TOMMAY
On my dyno run, the computer screen was showing the tech constantly hitting 130's & even 140mph one time. Won't see me on it like that, but I was cruising down I-95 this afternoon running around 80-85mph. Smooth as butter except all that damn wind trying to blow me off....lol
ORIGINAL: twofish
And it will knock em down like that as long as I can hang on.
So smooth,
makes a baby's butt feel like sandpaper.
mud
ORIGINAL: tattoofreaksb
if I so please.
When the rubber meets the road,
I will guarantee you there is absolutely no way your machine
will see anywhere near 130, much less 140.
Mathematically impossible - (unless maybe if you sink about 6-7 grand into it).
mud
