LED run stop turn tail light
Old Jun 13, 2017 | 12:11 PM
ilnighttrain06's Avatar
ilnighttrain06
Default LED run stop turn tail light
I have a 2015 Wide Glide. It has the led edge chopped fender light from harley installed. I wanted to get rid of my rear signals so I can mount the quick detach hardware for my sissy bar, but I didn't want to use the ugly relocation kit that harley has for the signals. So my solution was to install turn signals into my tail light. I attached some pictures of the light before and after the new LED strip that includes the signals. I am curious about the wiring for it when I am done.
Does anyone know the best way to wire this up? Do I just split the one ground on the new LED strip into two wires coming from the new LED strip? The new strip has wires for run, brake, ground, and one for each signal.
I have read mixed reviews on if I need a load resistor for the LED turn signals. I have read that after 2011, you don't need them? Anyone know if that is true(only messing with the rear signals)
Keep in mind that the stock rear signals are run/brake/turn and there is no actual dedicated stock tail light on the 2015 FXDWG.
Thanks!
Attached Thumbnails LED run stop turn tail light-tail-light-before.jpg   LED run stop turn tail light-tail-light-after1.jpg
Old Jun 14, 2018 | 07:35 AM
Ryan Bojengals Schaefer's Avatar
Stage I
Thanks!
just curious how that light worked out for you? I currently just run an led strip but am having problems shredding wires..
Old Jun 14, 2018 | 07:13 PM
rossWG's Avatar
rossWG
Thanks!
i have the chopped fender strip, and the relocation kit with LED side rear. i lost the run/brake from the side rear, and have a permanent red light on the my dash gauge. i am intrigued by your solution though i have the added problem of needing orange turn lighting
below is a link from DKcustoms, i dont know if this will help, on clarifying anything re module
http://www.dkcustomproducts.com/stea...bt-led-pnp.htm
Old Sep 2, 2018 | 11:05 PM
RDowns2016's Avatar
RDowns2016
Thanks!
alloy art has some cool strut mounted led lights I was able to mount my detachable backrest and saddlebags without having to use that ugly taillight relocation kit in my opinion it looks alot cleaner only thing is i had to relocate my license plate as well
Old Sep 4, 2018 | 06:11 AM
WildPhrog's Avatar
WildPhrog
i second the DK customs info. I wired in one of their universal stealth RBT LED kits into my street bob along with a magic strobes flasher from custom dynamics because I wanted an additional run/brake light on top of the stock bullet lights. You can view the DK Customs installation instructions pdf to help sort out what you’re looking for...there’s also lots of good info in the write up for their RBT LED lights...check the universal version, not just the plug-n-play to get a little better detail on figuring out the wiring. Good luck!
sarpeezy
Mar 13, 2014 06:50 PM
Bearcat1
Apr 27, 2013 09:49 AM
Bearcat1
Jul 15, 2011 02:38 PM
recon_sct
Apr 15, 2009 01:43 AM
warren888
Nov 20, 2006 08:51 PM
